it seems our oem drive shafts tend to balance better when aligned to the diff in the same way they came from the factory. I was very careful to make sure that this went back to same way. The RPS flywheel is fully balanced from the factory and you can't really put it in wrong. The bolt holes don't really give you the chance to screw up.
Im starting to think this is just normal resonance from an unsprung puck clutch and I'll just have to adjust my driving habits. Higher in the RPM band its such a nice change with the light clutch and the solid shift mount.
